► JasonS Spicy Red EX Turbo Showroom
89K views 164 replies 38 participants last post by  Dubbayoo
#1 · (Edited)
Ok welcome to my Showroom.
12' Kia Optima EX T-GDI
Spicy Red
Purchased on April 2014
Daily Driven
Currently 80k Miles
Current Mods:
Performance:
-845 Motorsports 4" SRI
-845 Motorsport front mount intercooler
-845 Motorsports Charge Pipe
-Nameless Performance Midpipe
-Nameless Performance Downpipe
-Synapse Engineering V3 BOV
-KSR Spec GDI Pistons
-KSR K1 Rods
-Stuffed turbo (6+6 compressor wheel w/ 9 blade turbine wheel upgrade)
-3-Port Theta II Throttle Body Spacer
-Saikou Michi Oil Catch Cans (PVC and Intake sides)
-Red Dress-up Bolts
-Custom Engine Cover Painting
-Custom Red hoses
-Ultra Racing FSTB, repainted brushed aluminum
-Torque Solution Lower Engine Mount
-Red Hella Super Tone Horns (2)
-BTR Custom ECU Tune
-Unorthodox Racing clutch pulley
-Lightweight Water Pump pulley
-HKS Super Fire Racing Spark Plugs M45XL
-Magnaflow Cat-Back System performance exhaust
Wheels/Suspension:
-19" Axe EX20 EX20 Gloss Black w/ Machined Face & Polished Barrel
-235/45R19 Nexen N'fera AU7 Tires
-Ceika 6 piston front Big Brake Kit (BBK) w/ cross drilled & slotted rotors
-R1 Performance slotted rear rotors
-Red painted rear calipers
-Aluminum front lowering arms
-Aluminum rear lowering arms
-Stiff Rings (front & rear)
Exterior:
-Anzo projector headlamps w/ dual CFL halos
-Tempest Direct 6K Low Beam HID Kit
-TRS HID Dual Relay Harness w/ capacitor
-Custom CFL projector fog light retrofit w/ halos
-Tempest Direct 6K Fog Light HID Kit
-Bospeed Carbon Fiber hood w/ vents (only 1 in U.S.)
-Color Matched DRL’s Bracket
-DRL’s (3-way)
-Rear LED Reflectors
-Color-matched Fluxion Design rear diffuser (rare)
-Rear Trunk Morris Club Wing Spoiler w/ brake light (rare)
-Rear Glass Spoiler w/ brake light
-Debadged and filled front
-Rear K5 Badge
-50W CREE Reverse Lights
-Chrome Turbo grille emblem
-Chrome Turbo trunk badge
-Auto Folding Mirror Mod
-SX Rear Bumper Swap
-SX Front Bumper Swap
-BMC ABS Front Lip w/ black accents (only 1 in U.S.)
-BMC ABS Side Skirts w/ black accents (very rare)
-Color Matched Splash Guards
-Black Vinyl Wrapped Rear Quarter Panels
-Black with Chrome Center Fuel Door Cover
-Black bumper protector with chrome lettering
-20SMD 5050 No-Error Front and Rear Amber Side Marker Bulbs
-Rear taillights coated in Nightshade
-Side mirror blinker switch backs (white, orange, off)
-Side mirror behind glass triangle blinker mod
-LED door handles
-Hybrid upper grille swap
-Hybrid custom lower grille swap
Interior:
-Custom Carbon Fiber Steering Wheel from SoCal Garage
-Custom dash and door colors throughout
-SX Cluster Swap
-K5 Head Rest Covers
-Full Interior/Exterior LED's
-Foot well LED Lighting mod
-Door LED Reflector mod
-Front LED K5 Scuff Plates
-Rear LED K5 Scuff plates
-LED K5 Door Catches
-Korean Center Console
-Front AND rear Cup holder led lighting (K5)
-K5 Aluminum Foot Pedals
-Black Door Striker Covers
-Black Door Checker Covers
-Black Door Striker Bolt Covers
-K5 Interior Door Mats
-OEM All Weather Molded Mats
-Custom color-matched JCS Gauge pod
-Prosport gauges (boost & voltage)
-Dynamat Xtreme (trunk, doors, hood)
-3M Thinsulate sound absorption pads (doors, hood, trunk)
Future Mods:
-Spintech 3337 dual mufflers
-Snow Performance meth injection kit
-Stance SuperSport coilovers
-Custom led and CF shift knob
-Switchback led strips in Anzo headlights
-Color matched eyelids
-Engine bay lighting
-Undercar lighting
-KSR V1 Spec Charge Pipe
-KSR Performance ECU Tune
Here are a few pictures of my car originally (see attachments), stock vanilla OEM everything. Also you see several pictures of the current state of the car. Amazing huh??!!
#29 ·
With all the mods I thought it was time to add some accent colors with dress up bolts from K5 Optima Store - Engine Bay Dress Up Bolts. Simple mod to pull the 10mm black bolts and replace with these. Here are a few pics but I got em all over, look close!
#30 ·
Next up was some more performance parts under the hood. I picked up a polished Injen intake from here: K5 Optima Store - Kia Optima/ Hyundai Sonata Injen Intake Systems, a brushed metal charge pipe and synapse blow off value from here: 2011+ T-GDi Charge Pipe - Nameless Performance and set up for the evening removing major factory components and replacing them. The charge pipe was an easy swap, the accompanying blow off value was easy to integrate into the factory solenoid as well, but the Injen intake, what a pain in the rear!!!! There are lots of other threads about reaching a couple clamps way down low to remove the darn thing and then putting the new one in and tightening clamps again. That was probably half my job right there. But engine compartment looks great, everything works, no spare parts left over and got that turbo sucking sound when I step on the gas now. Have a look!
Nameless Charge Pipe in brushed aluminum.
Synapse BOV hooked to factory solenoid and recirculation hose on
Injen intake of course
#31 ·
After all that work, I was kind of disappointed in the Synapse BOV sound. It was working but didn't seem right and didn't match up with what I expected from some of the other brands. So after a great amount of research here on the forums, I came across MDJammin and his thread http://www.optimaforums.com/forum/6-optima-engine-technical-discussion/32946-synopse-bov-proper-signal-setup-changed-so-loud-now.html which really turned things around for me. I also dialoged a lot with Synapse as well and basically I learned that the BOV I had was more of a performance part and needed to be hooked up differently to maximize its potential. So here is what I did... the BOV fires more frequently and much louder.
I bypassed the factory solenoid and used vacuum from my throttle body spacer. Im using 6mm (1/4") hosing in this picture coming off a brass 1/8" NPT fitting.
I split my vacuum line into two 6mm lines with a brass T fitting and take one line to port A on the BOV and another to port B. Both runs are identical length. I swapped out the smaller BOV input fittings with 1/8" NPT brass fittings as well.
The recirculation hose and adapter were removed (don't need it in our cars) so I am venting to atmosphere now. Also removed my pre-load spring within the bov.
Another picture from a different angle.
#32 ·
I had decided to get some items on my car color matched. I know a local guy who paints from his personal shop in his extra time. He gave me a great deal as long as it was on his schedule. That's cool by me. Look how these things turned out!!! and yes that is an SX bumper cover. ;)
#33 ·
So today I decided to snap a few new pictures of my engine compartment and my color matched splash guards, now that they are on. Engine compartment is complete from my point of view with the exception of a FSTB. She's a little dirty, but good enough to grab a few photos. If you have questions, just ask. Enjoy!
#34 ·
Next mod was a quick and fairly easy one. I removed my plastic side vents and replaced them with the 2014 model vents which have a silver swoosh with the word Turbo on it. They pop out from the side closest to the door first. There are two very tightly fit clips closest to the door that you can use a screw driver to pry out, or I have a hook that I used to pry out. Once those two clips are popped out, the entire thing just comes out. New ones just snap right in.
#35 ·
For my next trick its really a multi - part mod. I went out an got an SX bumper and had it color matched to my car as you probably saw in previous posts. So with that "extra" bumper sitting around I went ahead and hooked up some Camily rear LED bumper lights. The K5 Optima Store sells them in addition to several other places. Get the Camily ones though. K5 Optima Store - Kia Optima Rear LED Bumper Lights I also took the time to mount a Rear Bumper Lip Diffuser I had purchased from overseas. I got it color matched as well. The Lx/EX models need some help with bumper lips and the issue is all the after market stuff uses the small indentation the SX bumper covers have to hold or bolt on. So that part of my reason for swapping out my LX/EX bumper for a SX version. Here's some pictures of what I did.
the Camily Rear LED lights drop right in, replacing the factory reflectors
On the underside I drilled a larger hole for the 3 wires. Notice the light strip is secured on their side by factory screws
rear LED lights done, now to figure out the rear bumper lip diffuser
There is some 3M tape that attaches it along with some small screws as you can see in the picture
finished shots
#38 ·
You don't waste any time do you?! :D
Looks good man!
Thanks guys. I'm obsessed! And I hate you all as I keep getting more ideas after I see your work! :p
As you saw above I have a new bumper, a rear lip diffuser and the LED reflector lights all hooked up to that new bumper. So next I removed the one on my car. Here's a link: http://www.optimaforums.com/forum/22-optima-diy/1911-removing-rear-bumper-cover-tail-lights.html I had to remove all the crap from the trunk first and boy was there a lot back there! LOL After that I removed the rear bumper which is actually fair easy and quick. Here's the shot's of the removal.
All the junk and panels from the trunk removed. Lot more stuff than you figure!
Both bumpers in the grass. The plastic diffuser was a b*tch to put on the new bumper cover. I didn't have enough hands and had to get another person to assist.
#40 · (Edited)
Well thanks to folks like you and others, I have good advise to work from. And a long list of mods to do! :p
Well here are some fished pictures of the SX bumper on my EX-T with the brake LED lights, rear lip diffuser, black bumper protector with silver K5 lettering, and color matched red splash guards. Took some time but looks great!
#43 ·
Car is becoming nicer and nicer Sir :thumbsup: Nice rear diffuser too :cool:
Thanks guys. I love that rear lip diffuser. Easy to put on as well. I have some DRL's and horns coming up next!
#45 ·
Thanks David. I am getting close and will nominate my car soon. Just a few last things and I am indeed getting excited! I have a couple more mods to post but I'll do that another day. And my rubber for my wheels was dropped off by UPS today. Ahhhh the smell of fresh tire in the garage! :D
#47 ·
And since I mentioned it above, I cut my bumper today to make room for some DRL's I was also installing. Took a bit. I did the angle cut so I preserved part of the OE sides of my bumper. To get the cut correct, this is what I did... I measured two finger widths down from top and drew that as angle into the middle of the first (from the outside) large vertical bend mark and cut down from there. I first used a dremmel to dig into the metal and basically draw my lines, giving my rip saw a guide of sorts. I didn't have any metal cutting blades (swore I did) so I used hybrid blades, the ones that are made for wood but also cut thin metal. I managed to go through two blades and it took longer but it did work.
Note to self, don't assume you have the part, double check first.
#48 ·
I like how you did the angle cuts. Looks good. I go back and forth on the drls because of the cutting. But it would give me a reason to buy the tools. lol
#54 ·
Thanks everyone. I have a few more mods to post here. I was able to get a great deal done this past weekend. So this past weekend I took off my front bumper again because I had some DRL's to install, horns (above), color matched fog surrounds, hids, and wanted to wire my angle eyes as drl's as well. Well here are pics from my drl install. As you can see they are 3-wire drl's and the fog surrounds are color matched. Plenty of DIY on the forums on removing the bumper cover and installing drl's I don't need to link em. Enjoy!
Removing the OE fog surround. Handy note: you need to loosen up the lower plastic grill to remove or insert new surrounds.
Color matched fog surrounds. :)
Install onto the bumper cover one piece at a time. Install the surround, then the drl, then the fog lap. Trust me, you want to do it in these three steps.
Here it is all together. And wiring the two together.
Here is how it looks when turned on and from the front.
#55 ·
A few of you have wanted some more pictures of my headlights. They are amazing! So here they are, by popular demand...
#139 ·
#57 ·
So last weekend with my front bumper off the car I decided to switch out my low beams for HIDs. I bought some Tempest Sportiva 35W 6000K hids based on feedback from others and I must say I am pretty impressed with kit thus far. Its a relay kit, came with good wiring, some wiring shrouds and plenty of length and solid connectors. The color appears to be spot on and the brightness, omg, these are bright. There was two issues though. Sometimes the lights struggled to ignite and once ignited, there was the famous hid flicker and a decently loud humming coming from the relay.
I fixed the ignition issue buy installing a larger fuse than what came with the kit. I just went from 20a to 25a and made a large difference.
The flickering and relay hum was fixed after some good research here and elsewhere on the web. The issue is in how modern cars handle headlight electricity. They pulse the current to the lights which is why the relay hums and the lights flicker. Once I understood this I found the solution in capacitors that can be bought locally at Radio Shack. For $5 I got myself a 4300uF capacitor which I wired across the positive and negative of the relay input from the car headlight harness and flicker and relay hum disappeared. Good to know. I was about to spend a lot more on cancelers and it turns out I wouldn't have needed that part, so yeah for me! :) So here are some hid build pictures. enjoy!
How the relay is wired
ballast mounting and wiring on the passenger side
The 4300uF capacitor I added across the positive and negative of the car headlight relay input to knock down relay hum and headlight flicker.
I added identical capacitors right before each ballast to ensure a stable and even supply of power.
#59 ·
Next trick up for this pony is the Korean Center Console. I loved how classy the cup holder was and it sold me. If there is one thing I don't like about our Optimas, the cup holder area is just plain ugly, and that's being nice. The Korean version is more refined and has a classy sliding cover to top it all off. You can pick one up at several places if you are willing to wait about 4 to 5 weeks, or from David @ K5 Optima Store - K5 Optima Korean Spec Center Console Keep in mind you will also need this: Center Console Box Tray Utility Box Fit Hyundai 2011 2013 Optima K5 | eBay as the American center console box tray does not fit.
Here are some directions to removing your center console which is quite easy I must say. I didn't need to remove my shift knob, I just left it in the neutral position and was able to remove everything with zero issues. http://www.optimaforums.com/forum/64-diy-appearance-body-modifications/24705-center-console-sliding-door-over-cup-holders.html
Now my cup holder lights are separate and I got from some Korean website a while back (sorry don't remember). I painted the edges of them black to minimize any light bleed and drilled holes in the bottom of the center console cup holder to feed the wires. There are many places to ground a wire so the black lead was easy. For positive 12 volts when the headlights are on, I tapped a blue wire from the harness which supplies power to the two power outlets. its easy to find and confirm with a multi meter.
This mod made a huge difference to me in how it looks and with cup holder lighting is subtle and looks amazing as well. I can still fit my phone and bottles/cups of water in the holders just fine too despite the smaller size.
Korean CC on the bottom and our "American" version on top.
Removing the center console. Notice in the neutral position, you do not need to remove the shift knob.
Wiring up the cup holder led plates.
Assembled, ready to be installed in the car
This is how it looks in the car. You also see my K5 mats I own. :)
This is how it looks with lights out (I had dim light from the house shining in).
#61 ·
So over the weekend I decided to paint my calipers. Went down to the local auto store and picked up some red caliper paint. Boy does this paint have some fumes! Good thing I had a fan in my garage! I ended up with three coats per caliper and I have plenty of paint left over so I saved it in case of a chip or something. These were hand painted while on the car jacked up with the jack it comes with. I will say it took a while. I pretty much did one tire a night. The first coat dries quickly so you can immediately come back with the second coat. I waited about a half hour after to put on the third. I did go out any purchase better brushed though as the one it comes with sucks! And I did use a wire brush to clean off the calipers before I painted em; there was a decent amount of dust. Here are some pictures.... about $20 bucks and a couple hours for 4 nights! They look amazing on the car now.
#64 ·
Thanks guys. This isn't hard but it is time consuming. The brush the kit comes with is junk, just toss it. You can buy some better brushes at Walmart in their craft section. The paint goes on thick and the first coat will dry pretty quickly, fyi. I did use some masking tape to tape off the back of the brake pads, the bolts of the calipers, the bleeder valve and there are some thin metal plates that I taped off as well. Mostly I was just careful and took my time with the brush. I loved the paint as it seems to be auto-leveling and it turned out of so well after 3 coats. Make sure you clean the calipers first though, mine had a decent amount of brake dust I had to brush off. Good luck, take your time, and perhaps plan to do a wheel or two a night like I did! :)
