Oil changes, warranty info and tips
1 reading
33K views 79 replies 39 participants last post by  SXexcess
#1 ·
Provided you use recommended parts and oil, your car warranty stands. The Moss-Magnusson Act applies here.
If you have a metric socket set, you will just need a filter, crush washer and filter wrench.
The drain plug is a 17mm.
The Filter wrench is an 80mm 15 facet/flute wrench which you can buy from Advance Auto Parts (Part # W50468)
Torque values: Kia has a range for the filter and the drain plug.
I used just over the recommended median value for both.
14Nm for the filter and 40Nm for the drain plug (easy to remember!).
You will find that when you remove the filter, oil runs down the back of the plastic floor pan!!! Next time, I will insert a folded up piece of Aluminum foil (about 8X8") upwards into the hole and allow it to fold around the hole and hang down a little. When you remove the filter, it should not allow the oil to splash backwards into the plastic pan.
RECORDKEEPING:
IMHO, it behooves you keep a log (using the KIa service book in your glove box!) and retain all parts and oil receipts. If you buy genuine Kia filters and crush washer, which are very reasonably priced, and the specified oil (I use Mobil1 5w30 here in Texas), you really cannot get into trouble. Being as I am in a small town 70 miles away from the nearest dealer, I bought my accessories (rubber mats and mud flaps) plus oil, air and cabin filters and crush washers from Deland Kia in Florida. Nice folks, great prices, good service.
I do have one service "GOTCHA" for Kia Optima owners doing their own servicing:
When they installed the drain plug, they sprayed over the plug and crush washer when they sprayed the oil pan.
So, when you remove the drain plug, it appears that there isn't a crush washer (or you think you dropped it in the oil!!! WRONG!!! You will need to (carefully!), pry the old crush washer away from the drain plug BEFORE installing the new crush washer. Of course, if you aren't as anal as I am, it isn't a problem! LOL
FYI - A few years back, I had a warranty issue with Toyota and I supplied them with all receipts (I used Toyota filters and Mobil1 oils, and my service log. They didn't fight me at all......
#14 ·
I've been wondering about the same thing. I just called my local dealer and they said they use regular oil on an Optima oil change. BUT, I would feel better using synthetic oil as I did in my last car, a 2002 BMW 530I. Can anyone tell me A. What kind of oil I should really use? And B, when should I get my first oil change? The dealer says 5,000 miles but I'm reading about getting the initial oil out of the engine as soon as possible. Also, they charge $28.00 for a standard oil change and $75.00 for a synthetic one. Don't want to due it myself.
#7 ·
I can tell you from YEARS of experience with cars & engines of all types... do NOT wait 3,000-5,000 miles for your initial oil change. There's a LOT of particulate floating around suspended in your engine oil that you don't want running through your engine. If you do it yourself just note the date and mileage and save your receipts. You don't have to have the dealership do it to maintain your warranty.
#9 ·
i can tell you from years of experience with cars & engines of all types... Do not wait 3,000-5,000 miles for your initial oil change. There's a lot of particulate floating around suspended in your engine oil that you don't want running through your engine. If you do it yourself just note the date and mileage and save your receipts. You don't have to have the dealership do it to maintain your warranty.
this!
#11 ·
Find a trusted "indie" shop...
If you have a local independent repair shop that has a good reputation (we have a couple here in our town), then by all means take it to them.
You can buy your Kia filters and oil and take it to them to put in for you. They will usually note "owner supplied parts" and just charge you their shop rates for the job.
Keep the receipts....
#12 ·
They pretty much can't say anything about it. As long as oil and filter used are within spec, it doesn't matter who does it. If it did, they would be legally required to perform the service at no additional charge. That's the way it's been for a long time. I'd have to look up the federal regulation that covers this, but it's there. This is a big part of the reason why some high performance cars come with scheduled dealer maintenance "free". If you take it somewhere else with those, you can void your warranty. They don't offer it free because they want to be nice or give you yet another reason to buy, they do it so they don't have to eat the repair costs if you happen to have jiffy lube do the oil change in your Maserati.
#15 ·
If you have an SX, I'd highly recommend synthetic for use in a turbocharged engine. Any of the reputable brands (Mobil1, Pennzoil Platinum, etc) 5W-30 or 5W-40 will work great.
I'm a big proponent of changing oil early because 1) it's conventional oil of unknown brand and quality, 2) it's been subject to a LOT of short duration running (crank it up, drive it off the ship, shut it off) which can cause fuel dilution and condensation, and 3) Factory fill will contain the most break-in materials of any oil that will ever be in the engine - some smaller than an oil filter can catch. By the time 500 miles rolls around, my factory fill is headed for a recycling station and my car's full of Mobil1.
The reason I do it myself is cost. There's NO reason to pay anyone $75 for a synthetic oil change when for around $35 I can do it myself and be assured that it was done correctly. But not everyone has the time and facilities to do this type of thing themselves, so pay for what lies within your maintenance budget. Or....buy the oil yourself and take it somewhere that will agree to use the materials you supply. A lot of shops around me refuse to do that, so I bought ramps years ago and gave them all the middle finger. :)
#17 ·
I've had zero issues. One of the easier cars I've owned to change the oil in. Really glad they designed the splash shield so that it doesn't have to be removed to change your oil.
Not to assume you're an idiot, but be careful not to do what I've seen countless people do on "dumbass" videos...drive off the end of the ramps. Other than that, it's foolproof.
#18 ·
I will certainly be careful and not be that guy! I was mostly concerned about getting all of the old oil to drain with the front of the car at an elevation. All is okay with that?
#19 ·
Here in Canada the first oil change for the T-GDI is 5000KM or 6 months. I need to check if my dealer uses synthetic, else I will go elsewhere as well... But do not overlook the other "maintenance" items they are supposed to check at the first oil change..
#20 ·
I had to almost force my dealer to do a break in oil change at 2,000 miles. They wanted me to wait until 5,000 because they have to do it for free. Special deal I got with the car...free oil changes for a year, they just never set a limit.
#25 ·
Thanks, Snow. You've been a big help!
I bought the pennzoil platinum 5w-30 all synthetic for my first oil change. I read where the mobil 1 disappears a bit between oil changes.
#27 ·
Are you talking about the crush washer for the drain plug? I think my dealer gave me the one I got, because they didn't charge me for one, but I found it inside the filter box.
It's not 100% necessary to use a new one every time. I went for years on some cars by just flipping it over and re-using it.
When you switch to synthetic, or switch brands of synthetic, it's not unusal for a car to consume some for a while, but it'll stop. When I converted my first car (1978 Chevy Monza) from Yellow Bottle Pennzoil over to Castrol Syntec, I thought I'd lost my piston rings, but the consumption leveled out and it eventually stopped. Mobil1 isn't any better or worse than other brands in this respect.
#28 ·
Yeah. I was referring to the crush washer. I've heard mixed things about whether or not to change it out every time. I'll keep watch on the synthetic consumption and report my findings. Thanks.
#29 ·
I performed my first oil change yesterday at 1130 miles. I used Pennzoil Platinum 5w30 and the OEM Kia filter. When I took out the drain plug, I looked for the crush washer and I didn't see it. It looked like it may have been fused with the bigger washer that is there. Is that what I'm seeing? Does that bigger washer normally thread the plug bolt or is that the crush washer that's threading?
Anyhow, I installed the drain plug with the old crush washer I guess. No leaks that I can tell. To ensure I use a new crush washer next time, will I need to take some needle-nose plyers and forcibly remove the crush washer from the inside of the bigger washer? Also, I didn't have a 1/2" drive 17mm socket for the torque wrench to use with the plug or the filter so I guessed. I know - dangerous!! So far so good.
I've notice my MPG has risen since the oil change. BTW - The original oil is very dirty at ~1000 miles.
#30 ·
Nah..not dangerous. Don't go all ape-sh*t on it, but you're not gonna hurt it. I've never used a torque wrench on a drain plug.
The factory crush washer is painted onto the bolt. I took a pair of pump pliers and locked onto the washer, and spun the bolt with a socket wrench and it broke free. The fit is so tight, I had to thread it off the bolt. Just be careful not to grip the washer so tight that you bend it, or it'll be even harder to get off. I'm sure you're ok....I've never had one leak, even when I don't flip it over.
#31 ·
Thanks, Snow. My drain plug had a bigger washer than the crush washer the dealer gave me with the filter. Is that what I'm supposed to replace?
If not, is the crush washer supposed to go between the big washer and the plug or between the big washer and the pan?
#32 ·
It's hard to see on the drain plug because the sides of it are painted the same color as the plug. The new ones may be smaller, but they're still the ones you should use.
No..don't put another washer between the existing washer and the pan. Get the original one off at your next oil change, if you think you need to. (It'll probably seal fine for several oil changes).
