Removal and Installation
1. Remove the engine cover.
2. Disconnect the battery negative terminal (A).
Tightening torque
4.0 ~ 6.0N.m (0.4 ~ 0.6kgf.m, 3.0 ~ 4.4lb-ft)
3. Remove the air duct (B).
Remove the air cleaner assembly.
(1) Disconnect the breather hose (A), the recirculation hose (B) and brake booster vacuum hose (C).
(2) Disconnect the air intake hose (D) and then remove the air cleaner assembly (E).
Tightening torque
Hose clamp bolt:
2.9 ~ 4.9N.m (0.3 ~ 0.5kgf.m, 2.2 ~ 3.6lb-ft)
Air cleaner assembly bolts:
7.8 ~ 9.8N.m (0.8 ~ 1.0kgf.m, 5.8 ~ 7.2lb-ft)
5. Remove the under covers. (Refer to Engine and transaxle assembly in this group)
6. Loosen the drain plug, and drain the engine coolant. Remove the radiator cap to drain with speed. (Refer to Cooling system
in this group)
7. Disconnect the PCV hose (A), the intake OCV (Oil control valve) connector (B) and the OTS (Oil temperature sensor)
connector (C)
8. Disconnect the A/C compressor switch connector (A), the alternator connector (B), the OPS (Oil pressure switch) connector
& injector extension connector (C), the knock sensor connector (D), the MAPS (Manifold absolute pressure sensor) & IATS
(Intake air temperature sensor) connector (E), the ETC (Electronic throttle control) connector (F) and the vacuum pump
connector (G)
9. Disconnect the throttle body coolant hoses (A).
10. Remove the oil level gauge (A).
11. Remove the intake manifold stay (A).
Tightening torque :
18.6 ~ 23.5N.m (1.9 ~ 2.4kgf.m, 13.7 ~ 17.4lb-ft)
12. Remove the intake manifold (A) after disconnecting the vacuum hoses.
Tightening torque :
When installing, replace with new gaskets.
When installing the intake manifold, tighten the bolts and nuts with pre-torque first, and then tighten the bolts and nuts with
specified torque in the sequence shown
Tightening torque
Tightening torque
Hose clamp bolt:
in this group)
connector (C)
connector (G)
Tightening torque :
Tightening torque :
