41 - 48 of 48 Posts
Installed these in about 10 minutes - VERY easy install on my 2014 SXL. Since the CREE LEDs are a longer than the OEM bulbs, the only tricky part is maneuvering/angling them to fit into the opening due to lack of slack on the stock wiring harness. Output is great though!
https://imageshack.com/i/pbUiVweGj
Thank you again for your business and for posting pics. Gonna add one of them to our site if that's ok with you. ;)
Just completed this install myself (2012 SX) and can verify that unlike the later models, the entire lamp assemble needs to be remove (super easy, three nuts) to install the K5OS 50W Cree LED reverse lamps. Just follow the OP's #1 post to the letter. Hardest thing for me was getting the two rubber bump stops back positioned in the felt cutout.
Do test each install before you button it all back up to ensure the lamps light correctly (50% chance of reversing them I think, then they don't light correctly although they are not defective - it's just the way LED lamps work - like a Diode).
Results: I can see a better, brighter image in the OEM backup camera and in tight spaces where the light bounces off the walls better. Worth the $$$ in my opinion and they should last the life of the car (Cree LED quality).
41 - 48 of 48 Posts
