21 - 40 of 59 Posts
Very nice !!! I am also planning mine with the RGB LED's as well. I'm also going to add some a LED's under the back passenger seats and have them wired together. I'll post pics when I'm done.
That looks pretty **** easy. I'm worried about pulling panels off the doors due to rattles...
Discussion starter · #26 ·
Found a set of mood lights on this website.. Do u need to take the door off? Doesn't look like from the pics? someone chime in..
No.1
Wow, from the pics, it really does look like you can get around taking the door off. Looks like the old ones pop out and the new one pops in. If someone does end up buying this, please write up a DIY for this or at least confirm that you went this route and they WORK! This would be awesome!
****. Better than "How it's made". The never ending Joe Satriani guitar solo background music sealed the deal on this nicely put together You-Tube DIY.
No.1
You will still have to remove the door panel to install these lights. These look like replacement mood lights which basically one led that shines through a plastic tube so I am assuming it will still be weak just like the factory ones. Not worth it IMO. I installed RBG LED's in mine which are much brighter. I can also match the color of the head unit buttons to my LED's.
Any pictures or video of the install you did?
Thanks for the DIY I ordered the same strip you did from autolumination and will be doing this mod along with new Zeus Hifonics ZXI63 3 way speakers in all 4 doors. My car doesn't have factory mood lights, is this going to make the install more difficult? Im guessing im just gonna have to find another source of power to tap into.
Hey guys, just finished replacing the weak factory door pocket lights with bright LEDs. NilVlrod was the inspiration behind my mod in this thread, and I probably did mine in a very similar way.
I know I've seen several people asking for details on how to do this, so I put together a video tutorial.
You can see the video here:
mjm,
Great video! I plan to change out mine. Did you get the red or amber led from autolumination? I want to match the color close to the one above the USB. Thanks.
I have everything ready to go for installing these. However I do not have this option from the factory. Is there still a harness to tap into behind the door panel? Tia!
21 - 40 of 59 Posts
