could not pass the sun setting after the rain at duskGreat shots Scott. Love the background in the second pic!
Thanks John.Looks great Scott. (The car ain't bad either!)
Thank you. The height does not quite look right. I have some tinkering to do.Love the pics Scott especially the 2nd one, your car sits so well with the coils and it looks awesome man
No problem as usual my friend!!!!Thank you so much for the video!
You can purchase this taillights LED control module in here.
exLED Kia Optima LED Taillight Control Module (a Pair)
Thank you so much!
IN a few weeks I am going to get them adjusted not feeling the current stance :thumbsdown:
I have my turn signal module set up like that as well. Its the same module just a bit different wiringHmmm, very interesting Scott. How come only your outside lights are blinking where as everyone else's the whole inner and outer light blinks? Seems like a very good module and definitely different than what I've seen so far.
I hooked the module up to the inner brake light as well. I did not like the look of the entire tail light blinking.Hmmm, very interesting Scott. How come only your outside lights are blinking where as everyone else's the whole inner and outer light blinks? Seems like a very good module and definitely different than what I've seen so far.
John, I dont understand your question please elaborate.If I'm not mistake that's precisely the point of the module...
Scott - how does that play with the current turn signal module or does it replace it?
Yep exactly. This is the way the first module from FlyRyde was setup as well. Looks good Scott.I have my turn signal module set up like that as well. Its the same module just a bit different wiring![]()
What's different with this from the older module, or is it the same?I hooked the module up to the inner brake light as well. I did not like the look of the entire tail light blinking.
---------- Post added at 10:00 PM ---------- Previous post was at 09:57 PM ----------
The module I have is the same one that you have, I just did not hook it up to the inner taillightWhat's different with this from the older module, or is it the same?
Gotcha, Thanks.I have my turn signal module set up like that as well. Its the same module just a bit different wiring
Sent from AutoGuide.com App
Thank you for the response ScottI hooked the module up to the inner brake light as well. I did not like the look of the entire tail light blinking.
