Hey that is pretty cool Scott! How did you get it to come out like that?View attachment 89850 View attachment 89858Just fooling around with my camera last night. Thought these images are pretty cool.
Some new LED puddle lights I installed Saturday left that "glare"Hey that is pretty cool Scott! How did you get it to come out like that?
Just checking to see if US built optimas have a cutout in the passenger panel below the glovebox for a foot well light. If you look at page 56 here you can see the mod I did and what I am asking for.What are you guys up to?
That's pretty neat! Came out with a cool effect.Some new LED puddle lights I installed Saturday left that "glare"
Ahhh alright. Will take a lookIt is the panel above your feet if you are sitting in your passenger seat/ the panel right below your glove box if you feel around you will feel a hole the size of a zippo lighter
2013 EX and yup it is thereAhhh alright. Will take a look
How did you wire them, etc. Mine is a 13 and has it....built in the us.
Thank you both for checking. So Kia must use the same panel for US and Korean built cars. Thanks again!!!!!2013 EX and yup it is there
Scott,thank you for the video!
You can purchase this modules in this link.
Advanced search :: Search results - exLEDusa, beyond the limit
Thank you so much!
The third brake light you are speaking of I assume? If so behind the rear passenger side seat. I will call it the cushion by the door. If you remove that cushion the third brake light plug is right there.Scott,
Where's the easiest spot to tap in for the center brake light? I haven't even looked - I figured you could offer up a quick answer.
Thank you Sir!
We offer Two different styles, thank you!I was always a fan of this 2 way license light module but is there a reason why there is a delay when the light switches?
You will see the harness easily when you take off the cover, thank you!Scott,
Thank you Sir!
Mine had the original version one tpc module when I first bought it. Now as an option you can purchase the setup with version two tpc module to avoid the delay.I was always a fan of this 2 way license light module but is there a reason why there is a delay when the light switches?
Perfect - thanks Scott.The third brake light you are speaking of I assume? If so behind the rear passenger side seat. I will call it the cushion by the door. If you remove that cushion the third brake light plug is right there.
Thank you for the response.We offer Two different styles, thank you!
Thanks Scott, really interested in the new version which has no delay. Gotta check them out at their site and see for myself.Mine had the original version one tpc module when I first bought it. Now as an option you can purchase the setup with version two tpc module to avoid the delay.
Your welcome. John, this may help you http://www.optimaforums.com/forum/7.../7-optima-appearance-body-modifications/1997-third-brake-light-flash-mod-2.htmlPerfect - thanks Scott.
