Hi everyone I have a 2018 Optima SX
I would like to know if 245/40/19 tires on both front and back will cause any rubbing? Does anyone have that setup?
Will be putting wheels with 8.5 offset
Thanks
No clue, but what I like to do, is go to discount tire. They'll either know off hand or simply stap a size you want to try on and see the motion of a front tire. If it looks ok, then lower it and try its motion again. Luck finding the sweet spot!
Kia Optima Si 2014
I have a 2014 with 245/35/19 rims width 8.5, offset 33. Lowered. The back wheels were slightly cambered when they put them on to avoid rub.
