Ok guys, 09 Optima with Infinity SiriusXM. Everything works except the screen is white. No buttons, no info just blank. The unit has a reset button that I've pressed but it didn't help. Any ideas? Thanks.
I'm going to assume you mean your navigation/radio unit and not the screen in your dash.
Have you tried having car fully off, disconnecting battery for a ten minutes, and then reconnecting? If that doesn't work, I recommend taking it in. Most likely means it is a dead screen then.
Our '11 Sirius froze up during the summer and doing reset, fuse removal, nothing helped as the AM/FM, CD, and nav worked fine but Sirius dead, so bit the bullet and replaced with a used unit.
Latina-Haven’t tried disconnecting the battery yet. I’ll give that a shot this week.
Turbonut- everything else works great, it’s just the screen that’s not right. I probably will be replacing though from everything I’ve seen.
