2011 sx. Hit a deer a month back. I’ve got my car back and the left headlight was replaced with a OEM Kia headlight. I cleaned my right one but it doesn’t compare to the new one. The replacement headlight the body shop got was from kia and 800$. I don’t wanna spend the 800 to get a matching one. Are there any aftermarket headlights that look the same as the Kia one? Thanks in advance
Body shop can do a pro job polishing and then applying clear coat so oxidation doesn't return. Far cheaper solution.
When I bought the car the right headlight had holes drilled at the caps for the bulbs for some hid kit so the oxidation is inside as well. The outside was cleaned and it helped but not near enough to look even close to the new one.
