I hate NilVlrod do mine.. I felt the change ha
You don't want to give dealer a chance? I had them adjusted before New Year but the loss power came back so they ordered a new wastegate and replaced it for me a few days ago.I tried this at home and voltage does not go lower than 4.6.
I removed heat shield, C clip and loosen the lock nut.
Checked voltage with multimeter 4.6v
Rotated rod end clockwise and counterclockwise but meter reads 4.6v~4.7v
I made rod shorter and longer and checked both voltages but it's same.
What am I doing wrong?
I think I made my car worse than before...
Please help...![]()
Gotcha, I know exactly what you mean. What I did was drove it straight to the dealer and show them the power loss issue and then they believe me. They did replace my wastegate afterwards only because I showed them my CEL light was on, I didn't get a chance to test for power yet after they replaced it but knock on wood. Hope you get it fix soon, this wastegate issue is very common and Im sick of hearing a lot of members affected by it as well and Kia should automatically replace it or have a recall. Anyways, rant over and GL.I've done it in dealer before. it improved performance little bit but it still does not perform as day 1.
I called same dealer and asked to take a look at it again but they refused to make an appointment nor see it because the engine light is not on. They said they can't do anything unless the engine light is on.
Did you read the TSB, I'd suggest printing it out and following those instructions step by step. There are photo's other than the part where we use a multi meter to check voltage.I tried this at home and voltage does not go lower than 4.6.
Please help...![]()
Thank you for the reply. I didin't know I had to do ACC 3x on/off cycling after adjustment.Did you read the TSB, I'd suggest printing it out and following those instructions step by step. There are photo's other than the part where we use a multi meter to check voltage.
But you have to reconnect the rod after adj and ACC 3x on/off cycling. Then the 3rd time you ACC on, you get your voltage.
If you cannot obtain a change in voltage then you've likely stripped the gears out in the electric motor tightening the lock nut too much. It has plastic teeth on the gears inside that motor and they cannot withstand too much torque from you tightening the 10mm.
Also, the EYE on both rod ends have to be situated such that it's parallel with the backside of the 10mm nut. On the same plane. Otherwise, it might bind as the motor/wastegate moves and again strip the gears inside the motor.
The voltage spec is +/- 0.10 volts so anything within that spec should not throw a cel.
Also, make sure you check YOUR specific year model. There are different voltage specs for your PCM. They are not all the same.
you need the Kia Advanced Torque plugin installed. Then you have to load the proper custom PID's from the plugin app. But it's not a free plugin. There are directions on Kia Advanced down in the description and also listed on the Torque app forum if you good search it.Can anyone help me figure out how to find the ewg setting in the torque app. I had the app on my old phone and when I bought a new phone and installed the app and the kia advanced add on. The ewg isn't showing and I don't remember in past how I got it. Yesterday finally I started having the loss of turbo on startup and had to restart car for the turbo to work. So I need the ewg setting to monitor voltage now....
