My turbo quit working on my 2013 kia optima sxl I think it might be the boost sensor but the check engine light isnt on and it's not throwing out any codes how can I find out what is wrong with it or if it's even that sensor
When you say quits working, just no power but can hear the turbo spool?
First, check the wastegate voltage @ 4.1, and normally a code, but check all fittings as well as the intercooler for any leaks.
It's a start
If the car feels severely down on power and significantly decreased throttle response, it's most likely the wastegate actuator being out of range. It's not difficult to adjust if you have a multimeter and the adjustment nut isn't seized.
I had the same thing happen to mine and my adjustment nut was rusted on, no amount of penetrating oil was helping and I figure if it's going to break while I'm trying to fix it, I'm going to have the dealer break it and not me. $99+tax at the dealer to have it adjusted.
