Look on the left side of the trunk deck (right side if you're facing it)
This is the seat you want:
Behind the headrest, in back of the seat proper, is a plastic plug with a certain symbol:
Pry it up, and there's a cable loop inside. Pull that, and the trunk should open.
The latch mechanism is broken on the inside so when I tried the key it didn't do anything.Have you tried using your key in the keyhole above where your license plate is?
Awesome easy to follow solution!!Look on the left side of the trunk deck (right side if you're facing it)
