1 - 6 of 6 Posts
Hello Guys
I own Kia Optima 2016 SXL.
After changing the license plate lights, the trunk stopped working.
I can't open it with button in the cabin, with the button on the remote key and even with key inserted inside the trunk.
Could anyone please suggest any solution ?
thanks in advance
Maybe the related fuse 'popped' while changing bulbs? Find the related fuse and check it. Don't just look at it, actually test for continuity.
thanks for the answer.The thing is that when I press the trunk open button I can hear sound coming from the trunk. it means that electricity is going through wires. I doubt fuse is all good
2016 Kia Optima SXL
I found a similar issue/Solution = to Remove the rear seat and see if the in-the-trunk Cable Release mechanism works.
There was something in another Thread about Key Use triggering the Security System and It messing with Trunk Openings -- but since you're hearing sounds at the Latch I don't know IF that's Still a factor. Ask Dealer Svc IF they know about Re-Setting Security System.
I managed to open with the keys. I took to the repair and they oiled the key. Trunk was opened immediately
Ah Lubrication, it makes the world go 'round!
Might lube the other locks mechanisms while at it....
1 - 6 of 6 Posts
