1 - 6 of 6 Posts
For a 2015 kia optima sx turbo... mostly where would I connect the vaccum hose, and where would I install the red + wire and black - wire too??
2013 optima sx
Buy a vacuum distributor from lap3 performance. the stock locations to pull vacuum are small and annoying. It’s only $50. Red is positive black is ground to chassis
2013 optima sx
Where the factory bov is there’s a bigger line you can tap into but it’s 1/8 inch inside diameter i believe. It’s connected to a tan little box on the charge pipe
1 - 6 of 6 Posts
