I plan on this being a working thread that I will update and work on while I prepare to install and finally install an aftermarket stereo into a 2015 Kia Optima LX with the base stereo/speakers. I haven't found any exhaustive thread about this and highly encourage help. In fact I will have sections specifically asking for help/advice.
Crutchfield currently has not researched the 2014-15 and was unable to provide me with any information when I requested it. This is partially why I created this thread.
Please feel free to comment if you have input on various sections and I will update accordingly. Thanks all!
Mounting Kit:
Right now it appears the Metra kit (95-7359B double din & 99-7359B single din) is the best option and fits in with the stock look.
Wiring Harness Kit:
In this department Metra is the only dealer I have found as well (part number 70-7304). Seems to be plug and play.
Steering Wheel Control Adapter:
Here the Metra Acceess ASWC seems the be the popular pick (over the PAC options). I believe there is another popular unit but cannot find it at this moment... I will update when I do. I have used the ASWC on my last car (a Mazda 3) and it worked great once I figured out how to wire it.
I have found that the iDatalink Maestro ADS-MSW Steering Wheel Control Adapter is another option though I haven't found as much info on it.
Stereo Unit:
This is obviously a matter of personal opinion/choice. I have always been partial to JVC... but that is just me. I do absolutely require Bluetooth (for music streaming) as well as HD radio.
I plan on going for this one: Kenwood Excelon DPX791BH
This is a new unit that has Bluetooth, HD radio (I personally love this feature), integration with Android, and a new Bluetooth audio streaming system that will produce higher fidelity music.
Warranty Impact:
"Warranty should not be voided if taken to reputable company and as long as it is not an electrical short or faulty wring is the cause of the damage.
For Example if your wheel bearing goes out and car is wobbling down the road the dealership can not justify that your jvc installation is the root cause for your wheel bearing going out when internal failure of the bearing is the root cause.
However if you were to fry some of the on board computer/sensors/ect because of a faulty ground or a fire were to start bc of something then potentially you could be at fault causing a void in warranty." - CALIGROWN707
Miscellaneous Info:
Please comment below with tips, videos, and so on.
Mounting Kit:
Wiring Harness Kit:
Stereo Unit:
Warranty Impact:
Miscellaneous Info:
