Are you sure it's not the flexible steering coupling starting to go bad, before it makes noise?
KIA letter extending warranty for steering coupler
Please describe in more detail how the steering wheel is sticking. I
When I go around curves, turning the wheel about halfway, the wheel just wants to stick and stay in that position, if I were in a field, it would just keep going in circles, without me touching the wheel, which could be dangerous. And it seems to happen most when turning to the right.
Thank you for helping me.Are you sure it's not the flexible steering coupling starting to go bad, before it makes noise?
It does not make any noise, yet. Also I went ahead and purchased the Steering Coupler, it is due to come in tomorrow, is it difficult to install?Thank you for helping me.
I looked at your red letter "KIA letter extending warranty for steering coupler" and I tried to click on it, but nothing happened, Sometimes when I go around a curve about half way into the turn it sticks or freezes, and I have yank the steering back, to keep from crashing. I am concerned that when My wife drives, it will stick on her, and she will be unable to straighten it back out.
Thank you very much, for helping me, I went to Amazon and ordered it for my EX it should be in tomorrow, I guess I will go to UTube and see how it is installed. I really do appreciate what you and KingFatty has done, because I didn't have a clue to the problem.Ran across this on amazon, maybe it has some clues for you:
Late to the party, but our 2012 had the same issue and we are in Florida so it wasn’t due to cold temps. Had the steering column changed under extended warranty. Unfortunately 2 years later we have the same problem only this time, no warranty.When I go around curves, turning the wheel about halfway, the wheel just wants to stick and stay in that position, if I were in a field, it would just keep going in circles, without me touching the wheel, which could be dangerous. And it seems to happen most when turning to the right.
I want to Thank you for your help too, now in case, I forget later!
