1 - 11 of 11 Posts
2014 Kia Optima
Hi Everyone,
I have a 2014 Optima EX with a panoramic sunroof. Last week I had noticed the shark fin antenna cover wasn't sitting tight on the mount pad. When I pulled up on the cover it separated from the mount pad without much resistance and saw that the internal screw holes were in bad shape. It didn't look like any of the internals of the shark fin antenna were damaged. I used some silicone caulking and secured the cover to the pad for the time being.
I'm thinking about changing out the shark fin antenna with a low profile aftermarket unit. But, I noticed that the screws holding the cover on were coming upwards from the base pad. How much of a job is it to remove the old shark fin unit, and by having a panoramic sunroof does that make the task harder? Also, is the connecting cable on the shark fin antenna a universal connection? If I can avoid having to re-feeding another cable that would be a big time saver.
Any ideas or suggestions are greatly appreciated.
Looks like quite a few have the problem and to replace the headliner needs to come down.
Here's some info about the antenna/fix:
2014 Kia Optima
It’s a decent job with dropping the headliner. I glued mine back on a few years ago and it’s been great. At least you still have yours and it didn’t fly off somewhere
You may want to contact the dealership on it. There is a tech bulletin that they will have to dig for, but they should be able to replace it under that pending your specific situation with warranty and such. I got mine covered on my 2015 and was told it would have been even if it was outside the warranty, but that could have been fluff. Knowing these advisors - they'll tell you what they think you want to hear. There's a manufacturing defect that causes the holes for the threaded inserts to break down and cause the cover to come loose. Can't remember the years it covers. Good luck!
2014 Kia Optima
Hi Everyone,
Zipmac, I have the same 2014 with the panoramic sunroof and I just changed my antenna Assy due to a missing cover. There are 3 different antennas available depending if you have Nav and other options so make sure the dealer uses your VIN to order one. The recall starts at 2015 so yours is not covered as mine wasn't either. Carefully take your aft interior dome light down and you can see and reach the antenna. I loosened my headliner in the aft corners but you may not have to. I think just removing the light may be all you need. The two wire connections pull straight down. One large, like 16 MM ??, nut holds the whole thing in place. The fin covers comes with the antenna and you do not need to remove it to replace the antenna. Don't Over tighten the large nut. It was pretty easy. Good luck!
2014 Kia Optima SXL turbo
Hi Everyone,
yep same problem here mine flew off while driving every thing of mine worked fine since (i think xm works pretty sure i tried it since) sounds like its very common on these cars
I have a 2015 optima ex with pano roof and just notice the shark fin cover is missing from my antenna. I’ve been looking all over the internet for just a cover replacement and can’t find one - every place wants you to buy the whole thing and Kia wants to charge me $800 to replace and $190 for part. Please help
2017 Tesla Model X
eBay you can find it for super cheap!
1 - 11 of 11 Posts
