1 - 15 of 15 Posts
I had the same issue it's more than likely the pins on the bulbs are not making proper contact. Just gotta bend the pins on the bulbs
2017 Tesla Model X
If that were the case though, the OEM bulbs would still work. Sounds like a fuse may have blown. (Even though I know the OP checked them already)
I would leave the OEM bulbs in for now and if now still having trouble and the fuse is good (i'd replace that too), go back to dealer.
Does this optima have a reverse camera? Is it still working? Reason I ask is because the radio also turns on the reverse camera by the same +12 signal the reverse lights get. Here is a diagram of the reverse light circuit. Hope this helps.
1 - 15 of 15 Posts
