21 - 23 of 23 Posts
Hey Kias im new here. And just wanted some help So i ordered rims for my 15 Kia Optima
Specs
20"x9 +20 Offset all around
? Did i mess up by making this purchase? Is it fixable with spacers or not even?
Girst time buying Wheels and i gues i ** up but would like some input and advice pls thanks
Not certain as to which model/wheel you presently have, but let's try a couple:
205/65-16 6.5"x16-41mm
Inner clearance would be 11mm (7/16") less, while the outer position would extend 53mm (2 1/16")
225/45-18 7.5"x18-46
Inner +7mm (1/4") outer +45mm (1 3/4")
Using the above numbers will give you an indication as to where the new wheel will be positioned, and one can see that the outer part of the wheel would be out too far.
Here's a 20"x9" 35mm (The 20mm will move outward more than 9/16")
Here's another:
Needless to say, I think the 20mm offset will be a bit too aggressive.
21 - 23 of 23 Posts
