1 - 20 of 148 Posts
Vendor
R1 Concepts- Carbon Alloy GEOMET Rotors!
We're happy to introduce to you all our new GEOMET Carbon Alloy rotors! These rotors are a new and improved version of our "Premier Series" rotors. Manufactured for european and heavy vehicles, our High Carbon iron formulations enhances noise dampening characteristics, while providing high strength, and increased thermal conductivity compared to standard discs, which increases durability. Each rotor is engineered to match the OE vane configuration, including OE split-core technology to ensure proper and maximum heat dissipation. Additionally, all cores are dipped with a specifically formulated paint in order to provide a smoother finish inside the vane structure. The smooth finish will improve air flow as well as reduce the amount of machining require in or to properly balance the finished rotor during the mill-balancing process.After all of the machining processes are completed, each rotor passes a 100% electronic inspection station that measures over 20 attributes to ensure that each rotor meets OE specifications. This further guarantees that each and every rotor delivered to you is trouble free.
Geomet Finish
Finally we apply a genuine GEOMET Finish throughout the entire part, which promises to deliver superior corrosion protection. The GEOMET coating is processed dry, shipped dry, and ready to install without any additional preparation.
  • Superior Corrosion Protection- Provides excellent cyclic corrosion performance when tested to automotive manufacture's test methods incorporating heat, salt spray (withstands 400) and humidity.
  • Environmentally friendly, this meets the following regulations: Environmental Protection Agency (EPA), Chrylser CS-9003, General Motors GMW 3059, Ford WSS-M99P9999-A1 (Hex 9), the EU Directives on End of Life Vehicles (ELV) and Electrical Equipment (RoHS).
  • No Toxic Metal: Free of chromium, nickel, cadmium, lead, barium, and mercury.
BRAKE KIT
FT/RR CARBON ALLOY SLOTTED GEOMET ROTORS
FT/RR R1 OPTIMUM CERAMIC BRAKE PADS
TOTAL: $325 SHIPPED (2.0L TURBO)
TOTAL: $255 SHIPPED (2.4L)
FT/RR CARBON ALLOY DRILLED & SLOTTED GEOMET ROTORS
TOTAL: $350 SHIPPED (2.0L TURBO)
TOTAL: $280 SHIPPED (2.4L)
ROTORS
TOTAL: $270 SHIPPED (2.0L TURBO)
TOTAL: $205 SHIPPED (2.4L)
TOTAL: $295 SHIPPED (2.0L TURBO)
TOTAL: $230 SHIPPED (2.4L)
BRAKE PADS
R1 PREMIUM CERAMIC BRAKE PADS
FRONT HAWK HPS BRAKE PADS
EBC BRAKE PADS
LET ME KNOW IF YOU HAVE ANY OTHER QUESTIONS.
Vendor
Discussion Starter #2
Bump
---------- Post added 03-15-2017 at 03:26 PM ---------- Previous post was 03-14-2017 at 03:49 PM ----------
Hump day bump
Vendor
Discussion Starter #7
Bump
---------- Post added 06-09-2017 at 06:20 PM ---------- Previous post was 06-08-2017 at 06:37 PM ----------
Bump
Vendor
Discussion Starter #10
Bump
---------- Post added 06-22-2017 at 05:24 PM ---------- Previous post was 06-21-2017 at 06:52 PM ----------
Bump for new Carbon Alloy rotors!
Vendor
Discussion Starter #15
Bump
---------- Post added 07-11-2017 at 04:11 PM ---------- Previous post was 07-10-2017 at 04:40 PM ----------
Bump
Vendor
Discussion Starter #16
Bump
---------- Post added 07-14-2017 at 05:33 PM ---------- Previous post was 07-13-2017 at 05:48 PM ----------
Weekend bump
1 - 20 of 148 Posts
