I used a box that was big enough for the light to fit in and used a hair dryer ( I lost my heat gun when I moved) for about 15 minutes.That’s really odd that we can’t see the images. Unless it’s that way on mobiles.
I’m still so keen to mod my lights too... took them off but stopped at the heat gun phase as it was warping. Posted about DIY oven but no response.
Awesome thanks for letting me know! Hope it goes well for you. Did the glue and assembly come off easy enough after the oven?I used a box that was big enough for the light to fit in and used a hair dryer ( I lost my heat gun when I moved) for about 15 minutes.
Now I'm at the point to put the together and now the shroud will not fit into where it goes just past the reflector bowl
The glue was warm enough for the housings to come apart but wasn't very stringy so I didn't have a lot of cleanup but the small areas that needed it I used 91% alcohol on.Awesome thanks for letting me know! Hope it goes well for you. Did the glue and assembly come off easy enough after the oven?
Sorry about the picture problems, looks like Photobucket killed it.I started on doing just the retrofit part for the high beams. I was using the images as a guid but sadly all are blurred out and watermarked. I can’t see them anymore. I’m not exactly sure where to cut for the shroud. Is there any chance that someone might have these images saved?
