I have a 2018 LX. I thought that because my manual seat has power lumbar a power seat might just work and be a simple plug and play.
Well... That turned out not to be the case. I was on a road trip to see my Daughter (600 miles away) and found a power seat from 2018
at the local auto wrecker for a good price. I didn't really have time to research it beyond seeing that the connectors looked the same, I took a chance and grabbed it on the way back home.
I cleaned up the seat and installed it. The power lumbar works and has the added benefit of not only moving in and out but also can move up and down.
None of the other switches do anything.
I did observe that the new seat has a controller so it's "smart" to some degree. The larger of the 3 connectors for the seat harness uses 8 more pins that the manual seat and those pins and wires are missing on my LX harness.
I suspect, if I can power up the control box the seat should work, the other of the 8 wires may just be for door mounted memory switches that I don't intend to add.
I just want it to operated as a stand alone power seat.
I'm hoping somebody can supply me with a wiring diagram for the power seat. Thank you!!
