I have a 2014 Optima EX.
The passenger side fog light quit working. Thought it was the bulb so I replaced it and nothing changed. Swapped the bulb with the drivers side and the new bulb worked in the drivers side and the old bulb did not work in the passenger side - so it is not the bulb. I have looked at the fuses - nothing is clearly marked for the fog lights but unless there is a separate fuse for each side, that doesn't seem likely.
Has anyone else had this issue?
If so, what did you do to correct the problem?
Thanks in advance.
Check the connector for corrosion. A corroded connector will likely also have a broken wire, so use a voltmeter to make absolutely sure.
