1 - 18 of 18 Posts
Has anyone ever experienced this code p0299 low boost and what did you find the problem to be im getting this code on my 2013 optima sxl 2.0T right now can anyone please help
Not sure about that specific code, but it may be related to the wastegate adjustment for the turbo. There are other discussions on that topic.
its the electronic wastegate. its probably fallen out of spec and you need an adjustment. There is a youtube video if you are a DIYer but your dealership can do it as well for like $60 bucks. Its also best to take readings on the ewg when the engine is bone cold.
Temery - Any luck getting this fixed? I've got the same thing, no check engine light, but P0299 code via Torque. No turbo feel on acceleration but I hear the turbo whine. Other users have reported an intercooler leak. I have a 2012 SX with 127k salty Ohio miles. I have not removed the intercooler yet but the bottom section appears to be visually open where it was crimped, so I am guessing it is just a boost leak on the intercooler. Part is coming Friday so I will replace it soon.
So just had my car on the dyno today and with the stock intercooler and a 4th gear pull made 205hp then we put the wagner tuning IC in and it made 236hp well worth it to get the wagner tuning intercooler from the k5 Optima store 30hp gain
A larger intercooler isn't going to increase HP, especially when looking at 31. With the very low stock RW HP reading of 205, the OEM cooler was probably leaking. With 274HP and drivetrain loss of, let's say 15%, should have seen @ 233 when stock.
31hp gain
Never happen with just the intercooler!
I'll now ask you two questions, why the RW HP was so low when on the dyno, and how do you get 31 HP with just the intercooler? Actually with the new intercooler you're back to stock levels.
Read the following, first one I saw, dyno w/ 91 octane as some say a 6-8 HP gain, 234 stock and if I give them the 8hp, 226 STOCK.
I could look up more, but no time
Post the pre-Wagner IC dyno chart; I'm not gonna diisagree with your 31-hp increase claim, just curious as to what RPM the stock HP reading was taken. What's also interesting is that in the Wagner dyno chart the torque starts to drop and keeps steadily dropping after ~2K RPM, whereas in comparison the stock Sonata GLS in the Edmunds link has a much flatter torque curve. Guess something has to give when it comes to trying to squeeze out more HP...
Well I can confirm P0299 for was also caused by a bad intercooler. Bottom of it separated just like others have reported. I bought a brand new one from RockAuto for about $190 and was back to full power. Install for me taking the front bumper off for the first time was about 4 hours. Glad I did it myself.
Did anyone have a picture showing the separation when the crimping failed, or a picture showing how it goes back together and how you recrimped it?
1 - 18 of 18 Posts
