I went last Wednesday to the Kia dealership to have my ECU updated on my Optima 2013.
This evening when I try to go out for a drive. It won't start.
I press the Push to Start Button, but all I see are the lights turning on and off, and I hear repetitive "Clicks". I also see that my Push-to-Start button sometimes turns Yellow, and the immobilizer light turns on.
I've never had this issue... ever.
I tried all of the following so far:
Hold the button for 15 seconds (this attempts to start the car without the need for the brake pedal).
I unplugged the Battery for 20 minutes to try and hard-reset the Anti-theft system.
I just had the ECU Updated. This can't be a coincidence right? Anyone else experienced this before here? How did you solve it?
Have it tested first, but yes, a dead battery can rear it's ugly head out of nowhere with no prior problems.
Amazing how items appear after have the upgrade, but guess it's just coincidental.
When I had the update performed, within a mile after leaving the dealership the transmission gives an abnormal shift, never a problem before. Checked it the next couple of days and needed to replace the ATF temp sensor, problem solved. Know the sensor is a known problem, but after the update??????????????? Still not convinced it was just a coincidence, but I actually have no proof that the update would, or could even cause the malfunction.
I bought a die-hard that only lasted 3 years and 3 months. Ridiculous. So I tried a 5 year warranty Walmart brand this time to see if I have more luck.
LOL I know the feeling exactly--I've had two DieHard Golds that went bad prematurely, one before even 3 years had passed (thus I was able to get full replacement), the other shortly after 3 years had passed (thus pro-rated replacement)...and oh BTW this luckily happened to me *before* Sears changed their DieHard Gold battery warranty and removed the prorated feature of the warranty. Currently running a Duralast in my SUV--hopefully it'll hold up much better than DieEasy (I mean DieHard).
So it did turn out to be the battery.
I got the Walmart Brand as well cause I heard some good things online about them, and they had the 124R size in stock as well! It's got the 5 years Warranty (3 free replacement, 2 Pro-Rated).
Plugged it in, and she started right up!
Hopefully this one lasts longer than the Kia OEM one that had I had previously (barely lasted 3 years)
Yeah my oem battery only lasted 2.5 years and the replacement diehard 3.5 years! Hopefully the Walmart battery lasts longer but the Kia does take a small pretty lame battery size.
