Description:
The first 2-in-1 baffled OCC with "Triple Twist" technology is now available! No need to run two different cans, the new ADD W1 V3.3 Baffled OCC's 3 port design (2 inlet ports) allows users to hook into both PCV and intake ports with just ONE can! This design is custom made specifically for the Kia Optima & Hyundai Sonata, but can be used on other vehicles as well!
Oil Catch can's catch the oil and moisture in the blow-by gas that causes carbon and sludge build-up in the intake system and engine. It's advanced design assures the best performance and keeps the engine clean even under hard driving conditions.
These ADD W1 V3.3 Catch Can's come with a beautiful exterior redesign over the previous V2 model, sporting a gloss black finish with customizable colored ring inserts. The new design comes with a twister baffled filter which provides the best in oil and moisture filtration by keeping the air longer! This ensures all the oil drops to the bottom of the can. The newly developed twister baffled filter is one of a kind and the only air filtration system on the market!
Easy to install, and easy to service. Highly recommended for tuned vehicles! Features and Specifications:
ADD W1 V3.3 special engineered OCC
2-in-1 OCC w/ 3 port, 2 inlet system
Eliminates the need to run 2 separate catch cans
Revolutionary designed internal baffle "Triple Twister" chamber filter system
Closed loop system internal baffled Twister chamber filter Catch
Made from Lightweight 6061 Aircraft Aluminum
Fully customizable color insert rings available 8 different colors
Prolong and protect the life of your engine
Baffled interior for the best collection of oil
Available in Red Black Blue Silver Gunmetal PurpleGold Green
Limited Lifetime warranty
Package Includes:
1x V3.3 Baffled Oil Catch Can
2x 9mm fitting
2x 15mm fitting
1x 15mm hose
Optima Specific Mounting Bracket & Screws
Internal baffle "TRIPLE Twister" chamber filter catch
Complete installation instructions
*Optional vehicle specific catch can bracket
*Optional custom mounting bracket fits the 2011-2018 Kia Optima & 2011-2018 Hyundai Sonata models only
Collected this in just 700 miles of mostly highway, cruise-controlled driving. 45k on a 2015 SXL. IMO, this product has already paid for itself.
Is proud to present to the Optima community
The Ark Performance High Flow Cat Test Pipe
(BUY NOW)
Description:
Complete your full exhaust system with this awesome mid-pipe from Ark Performance
Resonated with a high flow cat, so you don't lose your catalytic converter
Fully polished 2.5" dual...
The ADD W1 Version 3 Baffled Oil Catch Can
(BUY NOW)
Description:
Oil Catch can's catch the oil and moisture in the blow-by gas that causes carbon and sludge build-up in the intake system and engine. It's advanced design assures the best...
Is proud to present another great product!
Kia Optima/ Hyundai Sonata BOV Sound Plate
(BUY NOW)
Description:
This anodized Billet BOV Sound Plate allows you to vent your stock blow off valve to atmosphere to create that unique blow off valve sound.
Not only do you get that great BOV sound...
Is proud to present the: Borla Exhaust System
FREE SHIPPING WITHIN THE CONTINENTAL US!
(BUY NOW)
Product Information:
Improve the look, sound and performance of your 2.0T motor with this stainless steel cat-back Borla Exhaust System.
Borlas straight-through mufflers and mandrel-bent exhaust...
Working with
To introduce to you the 2011-2019 Kia Optima &
2011-2014 Hyundai Sonata K&N Typhoon Intake System.
Built for performance and show, the 69 Series Typhoon™ Air Intake System is a free-flowing mandrel-bent
aluminum tube induction system designed to fit many sport compact...
