I have a 2015 Kia Optima EX just put trueharts coilovers on. Just bought rims that are 20 x 9 in front 20 x 10 in the rear ET 25. I don’t want any rub what tire size should I use 225? 235? And will I need to camber a little and with 25 offset will I need spacers.
Im running 20x9 +35 all around and currently have 235/35/20 tires. I also have the Truhart Coilovers and maxed the camber in the front on -2.0 degrees and sits nearly flush. I wouldn't run spacers with a +25 offset. Shouldn't have any rubbing issues depending on how much you drop it.
