Hello everyone. Looking to see if anyone has advice on how to upgrade the rear suspension on a 2019 Optima S. The rear suspension is very weak even though the car was purchased brand new earlier this year. If there are two adults sitting in the back seat the tires are just about touching the fender wells and with two adults and something in the trunk like groceries or whatever the car will actually high center on speed bumps and scrape the undercarriage. Need to find beefier springs or a way to solve this issue. Thanks.
2019 Stinger GT1
Hmm this seems odd. If you are having this issue and there has been ZERO modification to the vehicle, this is something you should address with the dealership, vs trying to change out the factory parts for aftermarket ones. No one sells aftermarket lowering springs that will raise the height of the vehicle, all of the aftermarket springs out there will only lower the vehicle even more.
