Tonight as I was driving my sunroof became possessed and started opening on its own. I attempted to use the button to stop it but it kept opening whenever I let off the control switch. As it opened fully I heard a few (bad sounding) clicks and since then it will not close.
Here’s what I’ve tried thus far:
  • Resetting the sunroof per the manual (at least 10 times)
  • Checking and replacing (with spares) the 10A and 20A fuses associated with the sunroof
  • Disconnecting the battery
None of these have worked.
Left to try tomorrow (before going to see dealer):
  • Replace 7.5A fuse (no spare on panel)
  • Replace 20A and 10A Fuse’s with NEW fuses
  • Remove roof panel (where switch is located) and disconnect control switch
  • Replace fuse near + node on battery
  • Reset stereo
  • Try sunroof reset 10 more times
Has anyone experienced this?
2015 Kia Optima EX w Panoramic Sunroof
FYI Battery was replaced less than 1 year ago
