21 - 31 of 31 Posts
Discussion Starter #21
I contacted support here but they said anything that low I’m going to have rubbing issues however when I browse around here and fitment site people have huge and wide wheels with the D2 springs and have no issues.
Same here. I don’t understand why
I went from the springs/shocks/struts with stock wheels and tires (225/40-18 on 18x7.5 et46) on my '15 SX to TruHart struts/shocks, H&R Springs and 225/35-19's on Rohana RC10's (19x8.5 et35). The same width tire does stretch a bit on a rim that's 1" wider...I'm not a fan, but it was the narrowest rim they offered. If I hit a big bump or dip, it will just rub the fronts in the wheel wells. No issues when turning or otherwise, as long as a big bump isn't involved.
Before:
After:
Discussion Starter #23
Before:
After:
Looks good! Did you have any issues with the stock wheels and tires on the lowered suspension?
Did the suspension a few days after the wheels/tires, so I never tried the stock wheels/tires on lowered suspension.
Discussion Starter #25
Gotcha, so I’d probably rub then as well since my 215/55r17’s tires are about 8.4” wide. The D2 springs are a drop of 1.6” and then add those with the truhart struts which would make it a little lower than yours.
Your 215's are narrower than my 225's, but only by 10mm, about 3/8", but they are taller, so yes, more chance to rub. I thought 1.6" was too far to drop myself, and went with the H&R's because they were only 1.3" drop in the front.
Discussion Starter #27
Thanks! So I did a little research and there’s really not much difference between our tires. As you can see below with the overlay ( yours in red ) mine is only a fraction taller but it’s also a fraction thinner.
Man I don’t know what to do hahaha. I want what I want without any issues and I don’t want to drop $500 on new suspension if it’s not going to be as low as I want and still have tire gap haha.
Can you please post another side shot of your car from a not so low angle of the camera?
248386
Discussion Starter #28
Well I bit the bullet, and bought the D2 springs and truhart shocks. I’ll post some photos once everything is installed and I’ll let you know if I run into any rubbing issues. Wish me luck
Hmmm, did Kia change to a different OEM 18" tire size sometime after 2015? The OEM 18" tire on my 2018 is 235-45-18 (19" approximate equivalent is 235-40-19).
I went back and looked and the original tires were 225/45-18's on my SX-T. The new tires are 224/40-19. I was off by 5% on the aspect ratios.
Interesting--so apparently sometime after 2015 Kia decided to go with a slightly-wider (at least on paper) tire...wonder why?
21 - 31 of 31 Posts
