1 - 6 of 6 Posts
So I have been running LED dome lights for a few years now, and the front ones burnt out/stopped working recently. I figured that before I went and bought some new bulbs I would try putting the stock bulbs on. When I did, only the right one lit up. I tried switching the left and right bulbs, flipping the switch between on, door, and off. I tried checking the fuses and from what I can tell they’re fine, also the fuses under the yellow clip. I don’t really have any ideas as to why it doesn’t work, because the right one and the rear dome lights work fine.
Could be the switch.
But that would make the right one stop working also right?
No try replacing just the switch that turns each light on individually
Discussion Starter #5
Oh, that makes sense. Can those be replaced individually? I can’t seem to find anything online, only the whole dome light assembly.
That I don't know. Some makes and models will let you but with this one you maybe out of luck.
1 - 6 of 6 Posts
