1 - 1 of 1 Posts
2013 Kia Optima hybrid no lights on dash not starting before you replace battery or fuses check the bracket that holds the battery in place in trunk. The bolt that connects the battery hold bracket to the body check this first.the ground cable is connected to it The surfaces are painted creating poor conductivity, sand surfaces top and bottom with 80 grit or your choice, your looking for shiny metal. And clean dry surfaces.
1 - 1 of 1 Posts
