1 - 11 of 11 Posts
2011 Optima
I just got this car about a week ago. Is the key fob,when pushed to lock doors, supposed to also lock the dr. door? It seems that no matter how many times I push the button, it does not lock the door. It'll lock from the inside. If I use the key to lock the door, then all doors will lock. 2011
2015 Optima SXL
Hi, I looked online at the 2011 menu options and though I don't see that specific feature for just the drivers door maybe you can check out the other settings to see if they work as expected. I hate to say it but sounds like a trip to the dealer to scan the sensors for the doors (If they can...)
Pictures courtesy of the Official Kia Manuals web site.
248427
248428
248429
If I'm reading the OP's post correctly, it sounds like he's saying that when he presses the lock button on his keyfob, all doors EXCEPT the driver's door will lock. I know there's a two-stage unlock option where one press of the unlock fob button will unlock just the driver's door while a second press of the unlock fob button will unlock the remaining doors, but I don't think there's such a two-stage option when it comes to LOCKING the doors. Sounds to me that something is amiss with the security module or whatever box controls remote lock/unlock.
" Sounds to me that something is amiss with the security module or whatever box controls remote lock/unlock".
^ This^
I don't claim to know everything about the 2011 Optima so I have to ask--when inserting the key in the door handle to unlock the (driver's) door...does the lock disengage electronically or mechanically--i.e., turning the key mechanically turns the lock tumbler mechanism? IIRC on my 2018 I have to pop the cover on the door handle, then stick the key in the slot and turn it to mechanically engage the lock tumbler. Guess my point is, has the possibility that the electronics in the door lock motor might have gone bad? One way to test for this is to see if you can lock/unlock the driver's door using the electronic lock/unlock button on the door panel armrest...although this precludes the possibility that the door lock switch and/or switch wiring might be bad.
Just checked it out on my 2012 SX, I believe it's electronic ie, I have mine set to open all doors and all doors unlock when key is turned.
2018 KIA Optima
It sounds like there is a 2nd key in the car. If my 2018 has 1 key inside, and I try shutting the doors with the other key or manually etc it auto unlocks the driver door to stop you from shutting your keys in the car.
1 - 11 of 11 Posts
