1 - 17 of 17 Posts
Can anyone tell me some reasons my car may not recognize the key fob and refuse to start? They power to the lights and stereo and such would turn on but it wouldn’t crank. The light with the car with the little key in it was lit up. I took it back out of the ignition and just sat there for a couple minutes. It finally recognized it and started. This is a little unnerving as this car take my children on trips far from home pretty consistently. I don’t want to be stranded because of a stupid key. Is there any way to start it without the key fob recognized like an emergency backup or something? Why would this just happen randomly?
With glove box open, on its upper left side is a slot. If it won't turn over due to lack of fob recognition, insert it there and it will start.
Mine has done the same thing once or twice. I lock and unlock with the fob and then it all works again.
I may check fobs battery when i have time, might be low?
This only works on the 2011-2013 Optima models, not on the 4th Gen models.
Boy, they don't make 'em like the use to, eh?
Well I guess OP is shxt out of Luck, sorry.
I think K5OS may have been referring to the start button that's next to the steering wheel; if your car indeed does not have this button, then that would imply that a physical/mechanical key is used to start the vehicle--in which case I'm curious to understand as to why the keyfob needs to be in proximity in order for the car to start since isn't your typical key ignition pretty much mechanical in nature (turn mechanical key in ignition to start)?
Yep, exactly what I meant.
Discussion Starter · #10 ·
Yeah I’m aware of what he meant by a start button. My car isn’t one with a “smart key”. After consulting the trusty owners manual I have discovered that the warning light I had mentioned earlier is not a key fob thing, it is the engine immobilizer or whatever. The only fix it lists is taking it to the dealership, but like I said I haven’t had the problem again. I’ll just chalk this one up to the cold weather. Thanks everyone for the discussion
Most cars these days have a PATS (Passive Anti Theft System) if it is not smart key equipped. This is a passive ID chip in the key itself that the car must recognize before it will allow it to start. Not sure if your optima has it, you didn't specify the year or trim level.
Some things that can interfere are large metallic objects near the key and steering column, other electronic devices on the key fob, or other such passive keys on the same fob.
Maybe what the OP was trying to say is that his car has an aftermarket remote start. My first thought would be to replace the fob's battery.
my car had the same problem and the issue was the inhibitor switch.
2016 Kia Optima SXL
Could be..... From an old Thread:.... [The Transmission Range Sensor (TRS) which is also sometimes referred to as the Automatic Transmission Inhibitor Switch] is basically just a device which senses what position/gear the car is in and sends that information back to the computer. This allows the car to display the current gear on the dashboard and
it may also prevent the car from starting if the computer believes that the car is not in Park/Neutral.
My Symptoms had to do with Gear Position Display being Blank (P, R, N, D ) and funny Shifting feel. This suggests other symptoms.
Fault Code was P0705..............AutoZone Fault Reader or buy one as I just did.
BAFX OBD II Reader $21 + $6 Ship
Software ...Paid $4 during Install for Pro Ver - Worked 1st time..... Box data ref's Torque App but more negatives there and more +++ for CarScanner.
Ah I just read the comments has no idea the new optimal doesn’t have a push to start . Interesting
I think you are misunderstanding the comments, because the new Optima has push to start.
Also note, Kia doesn't call the car an optimal. They no longer use the name Optima. It's called the K5.
Optima 2013 sxl pearl
I have a 2013 , I still call mines optima lol sorry 😂
1 - 17 of 17 Posts
