Here is some Youtube video of me and Isaac13SX during the installation process for the KK Rigid Collars.
Issuing fair warning, these vids were a last ditch effort to help forum members, but literally we had already started and said, hey - should we try to do a video :\ So, they are not the most informative, or even correct LMAO. But use them as a visual guide to help along with the written notes below and the instructions provided by KK.
You can crack jokes at my lack of automotive knowledge, Isaac does all the time.....it's cool. I'm getting there slowly.
The first thing you should do, Open up ONE bag at a time Front/Rear.
Lay out the Instructions flat on the ground.
Find each style Collar - ABC for the front / AB for the rear
Line each Collar style above the picture on the directions so they are all separated and grouped on the ground
Then pick up the directions and compare the photo and collar locations and locate them on the vehicle under pan
Tools:
Breaker Bar / Air Tool / Penetrating Oil (may need at least one of these for higher millage vehicles)
Deep 19mm 3/8 drive at least
Socket or Impact gun
Flash light
A pen or popsicle size stick
Something to support the unibody as you drop it down to insure no accidents happen
Pair of glasses - especially if you are using power or air tools
Couple of Notes on the FRONT:
- Remove the 14mm bolts that next to the two 19mm bolts on the front suspension support
- Then support the front unibody with something before you begin dropping it down for install
- Loosen EACH 19mm bolt that uses a Rigid Collar so it's still threaded to support the unibody weight
- Do not remove or loosen the 19mm that does NOT get the collars installed on it. It doesn't support the unibody
- Go through the hole (as big as a oil filter) in each lower A arm and loosen these 19mm bolts but leave slightly threaded
- Start by installing the Lower A arm collars one at a time/remove bolt, slide on collar with correct orientation with the collar facing upwards - BUT DO NOT run the bolts all the way up. Just hand tighten a little and move on
- Then go to the 19mm bolts one at a time and remove the bolt
- Using a flashlight, slide the proper double sided collar up in between the unibody and the body of the car. Use a breaker/pry bar to pull it down if it's not down low enough already. Use the flashlight to look through the hole until the upper collar drops in place properly. Then slide the bottom onto the bolt threads with collar facing upwards and slowly place the bolt into the hole WHILE watching the upper collar with a flashlight to insure that the bolt goes through the collar and doesn't knock it out of place. Hand tighten BOTH right and left sides after getting the collars in place.
- Now you can go back and tighten up the Long A arm bolts that you did first......and at this point, you can make your way around all removed/hand tight bolts and tighten them all back up while watching to insure the collars sink into position correctly and don't bind or crush into place.
Notes REAR:
- The rear is JUST 2 19mm bolts on each side located up by the wheels near the axles
- In the rear, you may be able to drop both bolts on ONE side, then remove by hand ONE bolt at a time and insert the upper and lower collars. Then put them in hand tight and do the other bolt on that side.
- BUT, once you have inserted your collars on ONE side already - DO NOT tighten up those completed "collar'd" bolts - WE found that you must leave this first side loose to allow the other side to drop the unibody enough to allow easy install on the other side probably due to the sway bars.
- JUST be SURE to support the rear end unibody so that if you unthread the bolts too far, the unibody doesn't drop down and cause an accident. It's heavy!
- Remember the rear has both TOP and Bottom collars on each bolt like the 19mm in the front.
As for torque specs - we used an air impact so they are "Brap Brap BRAAAAP" and on the smaller 14mm, we put them "brap brap braaah" that's my specs
I would recommend looking it up and using a torque wrench if you aren't experienced with automotive stuff. I had a pro watching my every move and I knew he would go behind me or stop me if I did something wrong. I believe Isaac can feel 5lbs of torque in his sleep with an air gun.
On a side note, I noticed that the mysterious collars provided in the D2 and K-Sport Coilover sets are remarkably similar in design/size. They must be meant to perform a similar function on 19mm bolts in certain model HUBs which have smaller hinge pins??? But in any case, These collars provided in the Coilover kits WILL work for this usage. They aren't as perfectly engineered for unibody usage as the Rigid Collars as you will see if you ever compare them side by side. But indeed they will get the job done. So this might be an option if you know someone like myself who happens to have 8 of these steel D2 collars
You just won't have enough to cover ALL locations as this nicely designed kit that Karbon Koncepts provided for all of us. You will still need to buy some collars to get the full effect.
Just be sure to match the collar TYPE with the pictures in the directions and apply them in the correct locations.
Here are some video's for reference points. I'm sorry we didn't take our time and prep for the install video's as it was an after thought.
***Please NOTE there are mistakes in this video, just use it as reference to get a visual for any of the above directions that are unclear. There are some mistaken info in the vids as I tried to narrate what Isaac was doing or going to do and it got a little messy at times LOL. But the combo of correct instructions above along with these visual aides, you guys should have no trouble at all.
Corrections - Only ONE 19mm bolt on the front gets the collars installed on them. The front most 19mm bolt you should NOT touch.
Also, Don't pay attention to my ABC description, it's wrong!!! Place the collars per the written instructions. A is double sided and goes on top
Hey, we were wingin it lol
Hope this helps you guys
Feel free to PM me or if you have my Cell# already, call me for help.
This is also posted in my build thread for anyone who needs an easy way to look up the directions. I always title my How To's and Tips with a searchable term that should be easy to find.
Tools:
Flash light
Notes REAR:
