Hey all , brand new here . Also brand new to working on cars myself . Just curious what the safest place to lower the car onto jack stands would be for a 2018 Optima ? Jacking it up isn’t an issue just not sure where to rest it on .
Same area where you jack it up.
If I'm going to use stands, I'll Jack it up under the control arms and put the stands under the rails.
Bottom of Form​
Kia Optima: General Information / Lift And Support Points
Tire Wheel Automotive tail & brake light Car Vehicle
When heavy rear components such as suspension, fuel tank, spare tire, tailgate and trunk lid are to be removed, place additional weight in the luggage area before hoisting. When substatial weight is removed from the rear of the vehicle, the center of gravity may change and can cause the vehicle to tip forward on the hoist.
Since each tire/wheel assembly weights approximately 30lbs (14kg), placing the front wheels in the luggage area can assist with the weight distribution.
Use the same support points to support the vehicle on safety stands.
1.Place the lift blocks under the support points as shown in the illustration.
2.Raise the hoist a few inches (centimeters) and rock the vehicle to be sure it is firmly supported.
3.Raise the hoist to full height to inspect the lift points for secure support.
Towing
General information Towing If the vehicle needs to be towed, call a professional towing service. Never tow vehicle with just a rope or chain. It is very dangerous. [Front] [Rea ...
Other information:
Kia Optima DL3 2019-2021 Service and Repair Manual: Front View Camera Unit
Schematic diagrams Circuit Diagram Repair procedures Inspection 1. In the body electrical system, failure can be quickly diagnosed by using Kia Diagnostic System (KDS). The diagnostic system (KDS) provides the following information. ...
Kia Optima DL3 2019-2021 Service and Repair Manual: Rear Combination Lamp
Components and components location Component Location 1. Tail lamp 2. Stop lamp 3. Tail/Stop lamp 4. Back up lamp 5. Turn signal lamp Schematic diagrams Connector and Terminal Function [A Type] Pin ...
Copyright © www.kioptima.com 2017-2021
Towing:
https://www.kioptima.com/towing-364.html
Hope this helps.
BVC
