I would buy a cheap scanner and run the code so you know whats going on. Sounds like only other option is to have it towed to a shop.
Classic symptom of the engine problem, flashing cel, normally only 2000 max rpm. At
times, like the daughter's 2017 2.4, got only 9 miles after flashing cel, then engine seized.
You can check the code, and if P1326 take it, or tow it to the dealer, new engine time.
