I finally broke down and ordered some of these. I had several issues, though, and it was getting late, so I pulled the resistors and put the old bulb back in for the night. Now, with no resistor or taps I get hyperflash on the mirror and tail, and the old front signal light doesn't do anything. This has me a bit baffled as the wiring with the resistor removed is essentially unchanged. Any ideas?
Also, when installing the LED's, they didn't seem to fit right. No matter what position they were in, you could pull on them and they'd slide out of the socket. I couldn't get them to fully function correctly, which I'm thinking is a connection issue or maybe the T-tap didn't bite into the thick black wire well enough. Not really sure. Any suggestions would be great. I basically have no turn signal on one side right now.
