Guys and Gals. Need some help please:
I haven't been on the forums for quite some time as my '13 Optima SX Turbo is my wife's daily ride.
So bought it new in 2013, do all the oil changes maintenance etc. using Mobil 1 5W-30. Just hit 80,000 on the odometer.
1) Car started leaking oil from the back of the engine and dripping onto the passenger side transaxle. Searched and found a few threads about members having the Turbo oil line feed replaced (updated part) so not sure if that's what causing it as it's hard to see up near the top to see where the oil residue is. Did KIA make it an actual recall that I can reference with the dealer if it is indeed the turbo oil line feed that is leaking? Any other common things it might be up top and behind the engine?
2) I took if for a test drive and noticed that car is running really rough at idle and it seems to stumble/miss when I rev the engine in park. Don't remember it doing that but I haven't driven the car in a long time (like 20k miles) and it does have a "check engine light" on. Searching again I see things about spark plugs being fouled, and also cylinder #2 issues and also different plug choices (higher heat settings). Scared the heck out of me. I thought OEM plugs would be good for at least 100K but maybe I'm wrong? Should I check/replace the OEM plugs and is there an updated plug version I should be using?
3) It always used a tiny bit of oil during the first 5 years but I noticed the oil consumption has really gone up in the last 25k miles or so; about 1/4 quart every 1K or 1500 miles. Again searching it seems that KIA won't do anything now about oil consumption and will only warranty engine if it throws code and seizes? What else can I do about the oil consumption at this point?
Any advice/opinions would be greatly appreciated
