We have a pretty neat product that is compatible with the high beams.
We carry the
RGB LED Color Changing Headlight or Fog Light Kit on our site.
The really cool thing about this product is that it has (4) LED Chips on each side of the bulbs.
Two of the LEDs is for the bright white light for the high beams, which is instant on and instant off.
The other two LEDs on each bulb are color changing RGB LED Chips that can be activated and controlled from your smart phone.
Since the color changing LEDs are completely separate from the bright white LEDs, you can run either of them independently of each other.
If you have no interest in the color changing feature, you simply don't wire up the wireless Bluetooth controller when installing the bulbs.
However, if the color changing LEDs interest you, you can see them in action below.
Kia Optima high powered LED headlights for low beam & fog lights, w/ built-in color changing RGB LED Demon Eyes. The coolest product to hit the market in 2018! This RGB LED Color changing headlight or foglight kit can be used on many different vehicles. As long as we carry your bulb size, they...
www.k5optimastore.com
