1 - 8 of 8 Posts
How warm does the bottom heated seat supposed to get I could feel the back warm but the bottom is not warm does it work off the car heater or is it electric or is mine just not working I just got this car 2 weeks ago
Ok I thought so. I will find some heater pads on eBay and wire them in. Does anyone know if they have to be a certain kind? Like carbon.:rolleyes:
Most any 12v operated seat heater pads will work, size is important part. Now sure about access to them, may need hog pliers to get underneath seat covers.
Seat heaters sure are important, not so much for butt warmth in central texas but to bring food home piping hot!!
Never tried to wire aftermarket pads into factory wiring, so I would splurge and purchase the factory pad @ $170.
Discussion Starter · #7 · (Edited)
The one I am getting cost 15 dollars for two. they have holes in them for air to go through. I don't see it cause a problem. If too much draw, the worse it can do it pop a fuse right? big different 7.50 to 170.00.
Body jewelry Silver Clock Wedding ceremony supply Jewellery
The one I am getting cost 15 dollars for two. they have holes in them for air to go through. I don't see it cause a problem. If too much draw, the worse it can do it pop a fuse right? big different 7.50 to 170.00. View attachment 250582 View attachment 250582
You get what you pay for and it's a PIA so good luck. I've installed nuimerous aftermarket pads, but never any for $7.50
1 - 8 of 8 Posts
