Hello, I have a 2017 Optima and I upgraded to LED Bulbs. The lights were working fine but now doesn’t. I tried putting in the old bulbs that work but still not working. I checked fuses and they’re fine. Does anyone have any ideas what to do?
Do you have a cheap test light? If so, check for voltage where the lights plugin. If you don't have voltage it might be the switch on the steering column. Appears many others are having issues with this switch.
2019 Kia Optima Lx
Have you tried checking them with the ignition on? Kia headlights won't work unless the ignition is on
