1 - 6 of 6 Posts
2014 Optima TF
Hi just joined the forum. I am in Western Australia and have a 2014 Optima. Have had the LH low beam stop working. Bulb looks OK. Cannot locate a fuse in either the interior or engine bay fuse panel for any of the headlights. Can anyone advise were the headlight fuses are located? The internet is not providing any answers on this.
2019 Stinger GT1
Hello & welcome to the Optima Forums.
Sorry to hear about the issue you're having there.
I don't think you are having an issue with a fuse.
I would remove the LH bulb & swap it with the RH bulb to see if it works.
If the RH bulb now works when put in the LH side, then you know it's just a bad bulb.
We do sell upgraded lighting kits for your vehicle, just let us know if we can help.
-David
2014 Optima TF
Thanks David,
I took the globe out and checked it. Now both low beam globes are not working or the LH parking light/position light. only got RH parking and high beam.
Regards
Frank
1 - 6 of 6 Posts
