Lol I feel like we are in the twilight zone!The irony in this comment….
Dude, go back and read your own posts.They said they didn't buy led. doesn't anyone read...
Ok I did. Now what?Dude, go back and read your own posts.
Just wanted to say that you were correct I was using the wrong bulb. I finally took my car to Kia dealership. I told them what the problem was and later that day the mechanic said come pick up your car. He said theybreplaced the car with the right bulbs. And they did not charge me anything. Gosh and one place told me it was electrical problems.Found this:
Switch on your headlamps, then go to the back of the car and see if the brake lights are on. If they are on disconnect the harness connector from each of the rear lamp units while keeping an eye on the high level (3rd) brake light. If the high level brake light switches off when you disconnect one of the lamps you know there is a short circuit between the tail light and brake light circuits within that lamp unit. Which is more than likely going to be caused by a faulty or incorrect bulb.
I'm certain it's not an issue, but make certain bulbs are installed correctly with the side pins in the correct location.
If you're buying a standard brake light bulb they are incandescent. your brake light relay is probably bad.I have been having this problem with my car. I drive this 2014 Kia Optima Lx. When I turn my headlights on the break light stays on at all times. No matter if I turn them on auto or on they stay on. My break light bulbs keep burning out and I have to replace them every week. It looks like the part where the bulbs goin that socket are burnt. Also when I turn my headlights on the traction control appears and when I turn them off and restart my car it disappears. It only comes on when I turn on my headlights and my car is started. Also on my right side passenger window I cant let it down using the driver side button. I can let it up on that side but I cant let it down, I have to reach over to the passenger side to let it back up. It will operate up and down on the passenger side, but only operate down on the driver side panel. I only drive my car during the daytime because my break lights stay on and people don't know when I'm about to stop. I do not turn them on while I'm driving in the daytime because you are able to see my break lights when I push them to stop. I don't know anything about cars so maybe reading this sounds a bit confusing. If anyone can give me some input please do. Nox Vidmate VLC
Brittle / partial rubber pad (pic is Kia updated one) makes brakes THINK that they're ON.Have you checked the brake light switch??? ....... (above brake pedal)
