Hey people. My name is Jon. I’ve got questions I’m sure people on here can help with. I’ll post in the right forum
2017 Tesla Model X
Hi Jon, welcome to the Optima Forums.
Do you have a Kia Optima at this time?
Tell us a little about yourself.
-David
Discussion Starter #4
Yes a newly wreck 2016. From Wichita ks.
home:
Electrician
Plumber
Handy man
Mechanic
Body guy
Cleaning crew
basically whatever task needs to be done.
Could sure use some help around the house, but I guess 1200 miles away would be too much of a commute.
Good luck.
Measure the distance between the center of left front wheel & center of the rear wheel, then do the same for the passenger side, if same, the wheel hasn't been moved back. Then take a check of the upright position. Guess one could use a level to see if both @ the same. If same, just strip the front and replace the parts.
It's a start.
Discussion Starter #7
Ok. Thank you. What’s hard is so much plastic was destroyed it’s hard to figure out what you need. And how to find the parts cause you don’t know the name.
