Perhaps a FI cleaner indeed won't do squat as far as dealing with spray tip deposits, but to argue that buying an FI cleaner is not worth spending any money on at all is somewhat questionable--not unless you are implying that there's no need to buy a FI cleaner because it is impossible for FIs to get clogged? Now you may counter-argue that all gasolines--no matter what brand--contain some sort of detergent agent to help prevent that from happening, but I think that everyone can agree that not all brand gasolines are created equal.A design feature of vehicles equipped with a Gasoline Direct Injection (GDI) system is the placement of each fuel injector directly
into the engine cylinder head assembly. Therefore, it is completely normal for the combustion process to create deposits on the
injector spray tip surfaces. Although spray tip deposits may appear to be heavy enough to affect injector performance,
there is actually no change in the fuel delivery or spray pattern.
As I stated before, save your money, a fuel injection cleaner isn't going to do squat.
Let me reply @ injector cleaners. If an injector is clogged, there is no cleaner that will help,Perhaps a FI cleaner indeed won't do squat as far as dealing with spray tip deposits, but to argue that buying an FI cleaner is not worth spending any money on at all is somewhat questionable--not unless you are implying that there's no need to buy a FI cleaner because it is impossible for FIs to get clogged? Now you may counter-argue that all gasolines--no matter what brand--contain some sort of detergent agent to help prevent that from happening, but I think that everyone can agree that not all brand gasolines are created equal.
