21 - 26 of 26 Posts
Mr williamhood,
The High pressure fuel pump is covered under 5yr/60,000 mile warranty - I agree to that. My car is out of the 5 year warranty (2012) by time but still falls below the 60,000 warranty. The warranty expires with the first milestone reached. KIA said they would pick up half the cost. But that still is about $450 for my end. Does anybody know the TSB number for the FCV function ECU update? What is FCV- Fuel somthing?
2014 Kia Optima LX
Cause of all the posts pertaining to high failure rates on the HPFP, and currently have extended warranty, my mechanic was able to process a claim and replace the HPFP. Paid my deductible of 100.00. This way, i have no worries getting stuck or if my warranty was to expire. Thank you for sharing your experience.
2012 Kia Optima SX-T
Mr williamhood,
The dealership can pull your VIN and see if your car got the FCV update or not. The FCV stands for "Fuel Control Valve" and in internal to the HPFP (it is an electromechanical component, driven off the camshaft).
Thanks for all your feedback. I got the car back today and there is not an ECU upgrade on the invoice. When I questioned the dealership, the dealership said there was no ECU Update for the fuel pump or FCV. They did replace the pump and a pipe. They also said that they do not replace many HPFP but did say they replace alot of starters on the KIAs.
The invoice also stated the part was leaking an making noise.
So unless some body can provide a TSB number or some other document I would suspect the ECU update is rumour that this is the reason this part fails.
Nope. I got the letter from Kia in the mail about two years ago. Took mine in and they did the ECU update free of charge. This was for an '12 Optima SX. Don't know if later MY is needed the update or not as every MY can be different.
21 - 26 of 26 Posts
