My driver front door, on my 2015 optima lx won't open from the outside. I roll the window down to use the inside handle. All other doors open from the outside handle, lock and unlock like they're supposed to. I also used the key fob on the inside to see if the doors will lock and they do. Also when I try the handle it does spring back like it is supposed to. I'm trying to figure what's wrong with it. Any suggestions on what else I can do? I forgot there's approximately 55k miles, if that helps any.
Don't know the inside so my only suggestion is to pull the panel and see if part is broken, disconnected etc.
Our '11 wouldn't open from the inside RR, took it apart and it was just a misaligned rubber bumper stop.
