A friend drove my 2013 Kia Optima and somehow turned off the interior automatic lights. When I walk up to the car the lights inside would automatically turn on and when the door opens. Now they don’t turn on. Can you tell me how to turn them back on? Thank you.
Switches are overhead on my 13 sxl.... Off-On-Door only
The lights turning on when you walk up to the car is a setting in the menu, it's called something like welcome lighting or something like that.
But I think, even if you have that setting on, you still need to make sure the physical switch is set to be on or door only. I think setting that switch off will stop the welcome lights from working, though I'm not sure.
Best to check both - make sure the switch is physically on, and make sure the software menu item is also turned on.
